TFX Xchanger 480
Thanks...I'm looking at a photo of an A71 at the moment and it seems to have a fairly busy looking interior...what are the options for placing the quad rad in here? How much of the existing A71 interior needs to be modded away? Can the rad be roof mounted or is that not the best position for it?
Sorry for the list of questions, I've used water for a long time but never had to worry about fitting anything bigger than a 120.2.
Thanks...
Would fit a 120.4 in the roof.
Although do realise you'd loose the usbs and other connectors on the top of the case at the front. You'll likely also loose 2-3 drive bays.
Don't think there is a single case that would take one of these without a sacrifice of some form.
No, I wasn't expecting it to be particularly easy. :)
Although I did read an article somewhere recently questioning the wisdom of watercooling cases that place the PSU on the floor of the case rather than the roof, due to the increased potential for mixing mains voltage and water in the event of a leak. I can't say it had ever occurred to me to worry about it before, but I suppose there is some validity to that. I know "leak test for 24 hours and you'll be fine" but accidents do happen and components do break.
I don't think it would stop me if it meant I could fit a 120.4 in the roof though!
