- 31 May 2006
- West London
Not usually in a position to see two of the same WU folding side by side on a PC but today is that day.
[08:05:56] Project: 775 (Run 21, Clone 119, Gen 4)
[08:06:18] Completed 200000 out of 250000 steps (80)
[11:21:18] Completed 225000 out of 250000 steps (90)
[08:14:10] Project: 775 (Run 43, Clone 47, Gen 5)
[08:14:31] Completed 202500 out of 250000 steps (81)
[11:09:14] Completed 227500 out of 250000 steps (91)
As you will notice both are at a simular step, the first starting 10 minutes earlier than the second. You may also notice that the second thread is taking 20min less per 10 steps aka 10% faster.
So is it my usage only affecting one thread (the first one started) and not the second or are Run 21 & Run 43 actually different, quick check of task manager say that mem usage is 31K and 33K (21 and 43 respectively)
so more WU using more memory running faster - reason
It's at 50% and other thread at 45% doh! working at 95% to stop EUE due to OC on stock cooling. sorry people.
but does show that same number WU's are not all the same. Just restarted run 21 now show 40K Mem usage....
- brain hurts off for some lunch
Edit - lunchtime folds (no user input)
Project: 775 (Run 21, Clone 119, Gen 4) 19min (reduced from 20) 32K % 45%
Project: 775 (Run 43, Clone 47, Gen 5) 17mins (reduced from 18) 40K % 50%
Would HT bias the computation of the greater usage (%) as 10% faster for only 5% extra processor usage (and more memory usage) does not stack up.
