That'll be why it's crashing then
Don
18 Oct 2002
Wargrave, UK
This is the 8400GS from my HTPC. I was wondering why it was locking up so frequently. Now I know.
That's 6 caps that have spilled their guts out.
You can probably replace them for a few quid if you're any god with a soldering iron, bit wierd that they've all popped though must have been a bad batch?
That's a first for me, never seen solid caps fail like that. I'm guessing they're a dodgy batch if nearly all of them have failed on a single card.
Out of curiosity, what brand is the card?
It's a Zotac 8400GS 256MB TC HDCP SPDIF
I agree that it must have been a bad batch. I've never seen a graphics card fail in this way.
I've seen other people post with a similar issue. Seems to be the same type caps too.
Looks like another dodgy batch of caps doing the rounds. Solid caps seem no better than the regular ones!
These aren't Solid Polymers - they're old style electrolytics. You have two options when you make a capacitor - you can either sleeve the metal can with the sleeve having the printing or you can print directly onto the metal can. Sacon (also known as Evercon, GSC) do this to make their capacitors look decent. In fact they're very poor indeed. They keep changing their name so they can keep flogging their rubbish. The FZ series is used on graphics cards and motherboards. Zotac, XFX and EVGA have used them, though EVGA seemed to be only motherboards.
1) Put a few drops of superglue on each one
2} Push the top of caps back down
3) list card on ebay
only Joking
