The Ampere RTX 3070 Owners Thread
What is your power limit set to? I found that stock voltage with max power gave me stable 2150 peak, 2050 after thermal soak. Dropping voltage would nerf the boost as heat built up, I suspect that as the internal resistance went up with temperature, the card couldn't get enough current; remember the gates are current driven. You could easily see that as a regression in my Port Royal / TSpy scores, despite higher max boost initially, the overall scores were lower.
109% stock and under volted. With my FE I'd constantly be power limited at stock boost clocks and when pushing clocks as far as I could. Best I can get is just over 2.1ghz.
How much was it? Is it the OC version?
Yup the OC version.
£699 (£559 ex VAT).
Far more than I wanted to pay.
But they had stock and I was just so done with queue's and waiting any longer.
** My work took the ASUS 3060Ti TUF I ordered from here.
Work also purchased a £3500 pre-built PC just so a my colleague could nab the ASUS 3090 STRIX OC in it.
Then we just split the rest of system up into two other PC builds and sold them on.
Personally I think he is mad with the 3080Ti coming soon... but it's his cash. :D
Managed to nab a 3070 Gigabyte Gaming OC for delivery this week but massively overpaid @ £640 from a well known place. Going to think about keeping it (still not sure as I don't game as much as I used to but thinking about cyberpunk)
Turned up today (not from OCUK).
It will keep me going until the 3080Ti drops.
Time to fire up Cyberpunk.
Welcome and on TROH.:)
The Roll of Honour.
Date 12/12/2020, Make Asus TUF, The Old School Gamer, Link
Date 09/12/2020, Make MSI Suprim X, Buffalo2102, Link
Date 06/12/2020, Make Asus TUF, easyrider, Link
Date 06/12/2020, Make Gigabyte Aorus Master, NismoSXZ, Link
Date 06/12/2020, Make Gigabyte Gaming, bonewood, Link
Date 02/12/2020, Make Palit GamingPro, Roach Model, Link
Date 01/12/2020, Make Asus Strix, Simon Belmont, Link
Date 01/12/2020, Make EVGA XC3, delvey, Link
Date 30/11/2020, Make NVidia FE, Pete @r..., Link
Date 30/11/2020, Make NVidia FE, SloppyChops, Link
Date 30/11/2020, Make Asus Strix, TheEvilMrFry, Link
Date 29/11/2020, Make Gigabyte Vision, KillaV, Link
Date 28/11/2020, Make MSI Ventus, LordV, Link
Date 27/11/2020, Make NVidia FE, danlightbulb, Link
Date 27/11/2020, Make NVidia FE, Fubsy, Link
Date 26/11/2020, Make Gigabyte Aorus Master, Venares, Link
Date 23/11/2020, Make Inno3D iChill X3, Jamestaylor92, Link
Date 23/11/2020, Make Asus Dual, Bazzarman, Link
Date 23/11/2020, Make MSI Ventus, El Jimben, Link
Date 19/11/2020, Make NVidia FE, MagicBoy, Link
Date 15/11/2020, Make Palit GamingPro, Blue160, Link
Date 14/11/2020, Make Palit GamingPro, Doobedoo, Link
Date 14/11/2020, Make MSI Gaming X Trio, rockhopper_tm, Link
Date 13/11/2020, Make Asus Strix, nicklog, Link
Date 10/11/2020, Make Zotac Twin Edge, Muller1989, Link
Date 10/11/2020, Make Gigabyte Gaming, tonym, Link
Date 10/11/2020, Make NVidia FE, sharpygsxr, Link
Date 10/11/2020, Make NVidia FE, Ree, Link
Date 09/11/2020, Make NVidia FE, BriT, Link
Date 09/11/2020, Make NVidia FE, IvanDobskey, Link
Date 09/11/2020, Make NVidia FE, ColdAsIce, Link
Date 09/11/2020, Make NVidia FE, Dontrocktheboat, Link
Date 08/11/2020, Make MSI Gaming X Trio, Jamin280672, Link
Date 07/11/2020, Make NVidia FE, McGraw, Link
Date 04/11/2020, Make MSI Ventus, DexterMorgan, Link
Date 03/11/2020, Make MSI Ventus, scrivz69, Link
Date 03/11/2020, Make Inno3D iChill X3, SDK^, Link
Date 02/11/2020, Make MSI Gaming X Trio, Invertigo, Link
Date 02/11/2020, Make NVidia FE, anuraj, Link
Date 01/11/2020, Make NVidia FE, sedy25, Link
Date 31/10/2020, Make Zotac Twin Edge, daniel2K16, Link
Date 31/10/2020, Make NVidia FE, Nickl245, Link
Date 30/10/2020, Make NVidia FE, MrPils, Link
Date 30/10/2020, Make Palit GamingPro, Martin James, Link
Date 30/10/2020, Make Palit GamingPro, Szydero, Link
Date 29/10/2020, Make MSI Gaming X Trio, dave_wood430, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3070
I have cut and pasted the 3070 Tier list based on PCB and VRM quality below. The reviewer has tiered them differently based on different criteria, by all means give the guy a click, it was a lot of work for him to do. I always go on PCB+VRM quality on the basis that i don't use air cooling.
Source: https://www.youtube.com/watch?v=N3lfXsa08CY&ab_channel=O!Technology
Tier 1
Asus Strix
Tier 2
Palit Jetstream OC
Palit Gamerock OC
MSI Suprim X
EVGA FTW3
Palit Jetstream
Palit Gamerock
Tier 3
Colorful Advanced OC
Palit Gaming Pro OC
Maxsun iCraft OC
Asus TUF Gaming OC
Asus KO OC
Inno3d iChill X3
Galax Gamer OC
Colorful Ultra OC-V
PNY Revel Epic-X
Palit Gaming Pro OC
Gainward Phoenix
Zotac Twin Edge OC
Zotac X-Gaming OC
Zotac Twin Edge
Colorful Battleaxe
Tier 4
Gigabyte Vision OC
Gigabyte Gaming OC
Asus Dual OC
EVGA XC3
Asus Dual
Gigabyte Eagle OC
PNY Uprising
KFA2 SG
Gigabyte Eagle
Galax SG
Gainward Chasing The Wind
Tier 5
MSI Gaming X Trio
MSI Ventus 3X OC
MSI Ventus 2X OC
Managed to order an ASUS Dual GeForce RTX 3070 OC and a Gigabyte GEFORCE RTX 3070 VISION OC today. Bought both because I am not sure which one will fit my case better but looking forward to them arriving!
here is mine, installed now:
The Roll of Honour.
Date 16/12/2020, Make Gigabyte Vision, avoidconfusion, Link
You'll have to remove me from the list unfortunately.
The misses has surprised me with a 1440p 32inch 165hz monitor for Xmas so managed to bag a 3080
Tier 1
Asus Strix
Tier 2
Palit Jetstream OC
Palit Gamerock OC
MSI Suprim X
EVGA FTW3
Palit Jetstream
Palit Gamerock
Tier 3
Palit Gaming Pro OC
Maxsun iCraft OC
Asus TUF Gaming OC
Asus KO OC
Inno3d iChill X3
Galax Gamer OC
Colorful Ultra OC-V
PNY Revel Epic-X
Palit Gaming Pro OC
Gainward Phoenix
Zotac Twin Edge OC
Zotac X-Gaming OC
Zotac Twin Edge
Colorful Battleaxe
Tier 4
Gigabyte Vision OC
Gigabyte Gaming OC
Asus Dual OC
EVGA XC3
Asus Dual
Gigabyte Eagle OC
PNY Uprising
KFA2 SG
Gigabyte Eagle
Galax SG
Tier 5
MSI Gaming X Trio
MSI Ventus 3X OC
MSI Ventus 2X OC
Thank you for finding this, super useful.
Anyone running a 3440x1440 monitor with the 3070? I can't for the life of me figure out if this card is enough VRAM for running this resolution for modern titles. I have been discussing this a lot recently and it seems that for Cyberpunk it is using almost the full 8GB of the video memory of this card on this res. I did run into stuttering after a while but I think it's more due to the memory leaks than the VRAM limit of this card. I am running optimized digital foundry settings + RT on medium with DLSS performance.
Btw, for those using Gigabyte cards, there's this cool Aorus master app that lets you run a 30~min auto curve test for the GPU, you can then apply the same curve via afterburner and save the profile. It doesn't check for memory clock though but I found it went up ~1k without problems. I can't OC the VRAM size tho KEK
