- 19 Dec 2003
- UK
Hi folks,
So I finally installed my Antec 900, after several issues with faulty PSU's (Jeantech 700W Storm!) I decided to buy another PSU.
Got a 700W Thermaltake Toughpower Modular, with 14cm Fan Its fantastic!
Anyway!
The Antec left me worried, because I couldnt be very neat with cabling, I did my best, but its quite cramped...
HOWEVER
It does not seem to affect temp because heres my temps!
CPU = 20 degrees (yes TWENTY!)
MB = 31 degrees
CPU Fan @ 750rpm
My CPU is a Core 2 Duo E6600, running @ 2.61ghz.
With my last case, a thermaltake Armor, which was bigger and more spacious, the cooling was
CPU = 28 degrees
MB = 39 degrees
So this Antec is FANTASTIC!
Cannot recommend it enough, if you are looking to buy one! Do it you will not be dissapointed!!!
Anyway!
HOWEVER
MB = 31 degrees
CPU Fan @ 750rpm
CPU = 28 degrees
MB = 39 degrees
