22 Nov 2009 at 18:36 #1 tatts tatts Associate Joined 8 Oct 2005 Posts 1,894 Location Cumbria I have decided to call it a day with water cooling and going back to air cooling but im so far behind in this area. Anyone advise on the best cooler for a QX9650? Not too bothered on a budget, i just want the best performance.
22 Nov 2009 at 18:40 #2 Bloodshed7 Bloodshed7 Associate Joined 30 May 2009 Posts 28 The TRUE is a great cooler. Great temperatures.
22 Nov 2009 at 18:49 #3 Stuart Gibson Stuart Gibson Associate Joined 25 Mar 2007 Posts 144 Location NE England Megahalems Better than the TRUE (on my rig, anyway!)
22 Nov 2009 at 18:55 #4 tatts tatts Associate OP Joined 8 Oct 2005 Posts 1,894 Location Cumbria Stuart Gibson said: Megahalems Better than the TRUE (on my rig, anyway!) Click to expand... Can i ask what temps you get with this at 4ghz?
22 Nov 2009 at 19:01 #5 Stuart Gibson Stuart Gibson Associate Joined 25 Mar 2007 Posts 144 Location NE England tatts said: Can i ask what temps you get with this at 4ghz? Click to expand... Currently core temps are 51 - 53c under load (seti@home), and ambient room temperature is 23c (quite warm!!). Edit: When I had the TRUE on this rig, core temps were 57 - 61c with roughly similar ambient. Last edited: 22 Nov 2009
22 Nov 2009 at 19:25 #6 manbearpig manbearpig Associate Joined 21 Oct 2009 Posts 1,485 Location Bedfordshire i am about to buy the megahalems for an i7, it has very good reviews and good temperatures.
22 Nov 2009 at 19:54 #7 tatts tatts Associate OP Joined 8 Oct 2005 Posts 1,894 Location Cumbria Thanks for all the inputs, it looks like i will also be ordering the megahalems
22 Nov 2009 at 20:17 #8 Geek. Geek. Associate Joined 12 Oct 2009 Posts 513 Location Backstabber central you won't go wrong with the megahalems happy installing!
22 Nov 2009 at 21:54 #9 Meridiusuk Meridiusuk Associate Joined 9 May 2009 Posts 1,072 did you use mx-3 paste or the stuff that it came with ? i am buying some mx-3 to go with this HS
22 Nov 2009 at 22:04 #10 Stuart Gibson Stuart Gibson Associate Joined 25 Mar 2007 Posts 144 Location NE England Meridiusuk said: did you use mx-3 paste or the stuff that it came with ? i am buying some mx-3 to go with this HS Click to expand... I used MX-2, but the stuff that comes with it is supposed to be just as good. If you're getting MX-3 you might as well use it!
