- 10 Mar 2010
Right i have a Asaka fan controller - its one of the cheap models
but i have managed to mislay the power cable (yeah stupid!)
So now i have decided that i will get a better one
But what one should i get? The fans i have use the 4point connector
but i have found (with help) : http://www.overclockers.co.uk/showproduct.php?prodid=CB-012-AK
would this work on other models that use the 3point connector
or is there a good model that will directly connect to the fans
i have looked at the following :
http://www.overclockers.co.uk/showproduct.php?prodid=BB-001-ZA&groupid=701&catid=57&subcat=189
with this i would need the above connector correct?
What do you think? is it a good option?
i have 2 LED fans currently, will be adding a 3rd very soon
so would i need 3 x of the above connector correct?
