Hi
This is going to seem like a very tight budget to a lot of people, but unfortunatley its all i have at the moment.
I would like to know the best Motherboard, CPU, and Graphics combination i could get for £300. I've decided to upgrade now on a more limiting budget because i just can't wait till the new year.
The MOBO needs to be compatible with a SATA 250GB drive, and 1GB stick of DDR2 PC4200 memory. I was hoping to get a low spec conroe system but am not sure if this is possible, if not i would probably go for a AMD system as opposed to intel. Also, i've currently got a 400W PSU would this be enough?
This will be used for gaming, i know it won't be the best but considering i'm used to an intel celeron with onboard graphics i'm sure i can do better
Thanks
Thanks
