- 27 Mar 2004
- Between Realities
I'm trying to get together the best overclocking system money can buy, I've finally got together some money, And can go forward and purchase now. Which is great.
But I want to spend money on.
A Quad core
RAM
Motherboard
Graphics card
but I want the most overclockable CPU, For instance, I want a processor that will overclock far, With More cache, for maximum performance.
Then I want 4gb or 8gb of RAM, I know a lot of peoples general opinon is that 8gb is a waste, but I'm happy to buy it, IF i can buy it, Put it into a motherboard that will allow me to get a good overclock. I'm unsure if any motherboard/8gb RAM/Quadcore CPU combo allow good overclocks yet, Am I right?
Then I'd like to also purchase the best Graphics card, That has the best Overclocking potential, Is that still a case of buying the 8800 GT? I'm right in saying the memory bandwidth is wider than that of the GTS, Allowing the GT to surpass the GTS and almost equal GTX on occasion. This is still accurate? And has ATI not got any overclockers out there that equal this particular card yet?
Then there is the most important part, The motherboard, It need to be able to handle the 8gb RAM > CPU overclocking combination, If thats no doable, then the best 4gb RAM > CPU overclocking combination.
I want this system to be tight, and perfect. I do understand that components are the luck of the draw, And i could end up with a dodgy chip which will put a spanner in the works. BUT, Let's say for sake of argument, Fate is on my side. What's the best bits of kit to build the BEST bit of kit
Oh, And just to add this onto the end of the thread, I'll obviously need a rock solid PSU to run the lot. Hiper is out of the question, As after the last one i had died and destroyed my Graphics card, I hate them
After all this build up of building a power house of an overclocking system, I do have to let you enthusiasts down slightly and tell you it's all to be done on Air Cooling
Hard drives and the like I can spec myself, I could probably spec this myself, but you guys deal with the best overclockers day in day out i'm sure. And that's what i'm looking for.
Any help would be very much appreciated.
All advice given, I will go look at various benchmarks and what not, as I do like to be thorough when purchasing new components
With regards to a budget.
it's not really a set budget, If i need to save for another week or 2 in order to add to my current budget to get the best system, I'll do that.
A Quad core
RAM
Motherboard
Graphics card
