I've just got a new computer with Windows 10 installed.
I've already managed to install MS Office but before I did I created a restore point "Prior to MS Office".
All went OK.
I then decided to install another program (Mindful) so I created another restore point "Prior to Mindful".
I've now discovered that I would have been better installing an older copy of Mindful and then upgrading so I'd like to remove Mindful.
Would I be better just uninstalling mindful or use the System Restore function?
Is it best to uninstall programs or use the system restore as I believe that even if programs are uninstalled using the uninstall function certain files are left in the registry but a system restore would prevent that from happening?
Thanx
All went OK.
Thanx
