The best way to learn?
30 Jul 2004
East Sussex, UK
Howzit guys.
I'm wanting to learn more C++. I have a program called Visual Basic 2005, not too sure it's the best thing to be learning on. Anyone got ideas on a better way of learning C++ and programming in general - Where on the Internet I can get help tutorials ect from?
Also I want to learn some Web Designing, again, where's the best place online to go to?
Thank you very much!
If you want to learn C++ then Visual Basic is no good for you. You'll need Visual C++ 2005.
TrUz
Although installation of the IDE is far easier, once you get to the nitty gritty of programming C++ I'd start with a straightforward compiler/linker like g++ (the gnu c++ compiler), it works similar to javac java compiler.
It took me SO long to get out of the Microsoft mindset because I started C++ using crappy Visual C++ 6.0... but now am far, far better off for actually knowing what a compiler / linker is and how to use them.
Well, I need to learn the code behind is, and I am trying to find a good place to start - Interweb can be real confusing at times :(
Tutorials on the net will never match a good book. Why do you want to learn C++ any particular reason?
Shoseki, Visual C++ isn't 'crappy' it is a tool used by the majority in industry.
Well, I would like to start programming really. I'd love to be able to design and build programs. I would get a book, however here in S.A I really wouldn't know where to start. :(
Thank for the help!
I am also trying to learn C++ but i have the advantage of coming from a C background instead of VB. Also my dad is very competent with C++ so he has been giving me hints and pointers (pun intended)
The site i'm using is cprogramming.com which is good but doesn't give enough real-world examples for my liking. There is no alternative to a good book though.
The majority of the closed source industry ;)
Oh another open source zealot what a surprise. Why do you think people like John Carmack use Visual C++ not because he loves billy boy but because it's a good tool. And it's not as if he loves closed source because he's the one pushing OpenGL.
Also, how is the best way to go about this? Just read and follow or is there a more productive way of doing this? I don't want a 'Learn over night' job, if it takes time, so be it. :)
So the Microsoft Visual Basic 2005 Express Edition is not the right thing to use?
Also, on a side note, how does one make a GUI for a program; is that in the code?
Ice On Fire said:
I'm busy saving all those tutorials to Microsoft Word. How do you mean, "Steep learning curve."
What's the best way of doing this?
To be honest with you C++ isn't exactly a nice friendly language to start with. In terms of the best way of doing it, start from the bottom read a tutorial and make sure you fully understand before moving onto the next otherwise it will haunt you later on.
