The biggest, (almost) free upgrade to my sound system, ever!
6 May 2004
London, UK
It might be a really obvious point for some people, but I only had this revelation very recently. I'm posting this because I guess a lot of people also do what I used to do, without thinking about the potential difference it could make.
I have the Videologic Sirocco (2.1 system) and used to put the two speakers on the desk. The tweeters therefore were roughly 20cm below my ear level.
About a week ago, I had those rail shelves put up on my wall directly in front of my desk, which meant that I could put the TFT screen and the speakers on the lowest shelf to be on level with my ears. Then started listening to music.
Wow. Such a difference. It's like someone took the layer of velvet off the front of the speakers. There are so much more high frequency detail and spatial awareness than when the speakers used to be on my desk. It used to sound pretty decent, but now I realise that it was really nothing like what it could sound at the right height.
Now I'm going through different music and hearing it in a new way for the first time... and I didn't even need to buy any new electronics! Just a smallish amount of money on the shelving unit!
Just thought people might be persuaded to try out different arrangements for their speakers - in my case, it wasn't anything to do with a £500 DAC or a new CD player, just having the speakers at the right height.
you know, you are right. just got to find a way to get the right one higher, the left is on the sub. on top of the case seems a bit high but ill test it out
The lesson here: high-frequency sounds are more directional. This is why you'll sometimes see nearfield monitors in recording studios on their side, because if they were upright, they'd be firing above the ears of the desk operator [Yes, you could argue that they should get better monitor stands, but any studio owner who would rather spend money on speaker stands than mics or outboard gear is clearly a freakish anomaly].
Conversely, low-frequency sounds are much less focused, which is why sub placement isn't so crucial and why - if you've ever lived in a block of flats - you can never be sure where that damned loud 4AM party is :D
Here endeth the Adam Hart-Davis moment.
Same principle applies to front and rear speakers in 5.1 set up.
Didn't realise how important until I had put 'em all at same ear level
I have some ribbon/planar tweeters and this effect is very pronounced with them. Moving just a foot under the speaker (but while 1.5m away) all the treble just dissapears. Wide horizontal dispersion though and brilliant imaging when used properly.
