wizardmaxx said:Found this
"The E6 steppings are the only ones able to handle 4 sticks of RAM, but whether or not there is any difference in their overclockability, I'm not sure. I do know that almost all of the other Toledo cores overclock very well. "
It sound like the E6 are the newer Toledo dual cores with one core disabled (ADA3700CF) and the E4 are the San Diago cores (ADA3700BN). The CF has a lower voltage as well (.05 fewer volts) due to the new core.
I may not be 100% correct though.
All 939 cores can use 4 sticks, just older ones like clawhammer/newcastle will only support them at 333 Mhz. E4/E6 can run them at 400 Mhz np.Quoting text from another forum, but I agree with you that whichever one you use you would expect all four ram's to work. Mabye the E6 just does it better.
