If anyone can help me with this I will be eternally grateful:
It happens when gaming and the symptoms are everything freezing as the cpu spikes for 2 or 3 seconds (during this time the sound is garbled), then everything will be back to normal for a further 2 or 3 seconds, and then back to freezing, then back to normal - rinse and repeat until the PC is rebooted. Sometimes I can game for hours or even days without it happening, other times it will kick in within seconds. Two Windows 7 installs and two Windows 8 installs have made no difference. Nothing is overclocked (i5 3570k and GTX670) and prime can run without errors for 24hrs. It's now at the point where I'm considering flogging the lot and starting again
Log Name: System
Source: nvlddmkm
Date: 11/07/2013 21:36:56
Event ID: 14
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Queeg
Description:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
0f12(22b0) 8400e927 a5a52138
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="nvlddmkm" />
<EventID Qualifiers="49322">14</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-07-11T20:36:56.137326100Z" />
<EventRecordID>1865</EventRecordID>
<Channel>System</Channel>
<Computer>Queeg</Computer>
<Security />
</System>
<EventData>
<Data>\Device\Video3</Data>
<Data>0f12(22b0) 8400e927 a5a52138</Data>
<Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
Log Name: System
Source: nvlddmkm
Event ID: 14
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Queeg
Description:
\Device\Video3
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Security />
</System>
<EventData>
</EventData>
</Event>
