The Egyptians built monolith Pyramids but the Amazonians built huge Geoglyphs
  • Thread starter Thread starter mrk
  • Start date Start date
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Copied from Treehugger
With the aid of satellite imagery from Google Earth, soon archeologists in Brazil will be finding more and more large geometric designs carved into the ground in the Amazon rainforest. The geoglyphs are believed to have been sculpted by ancient people from the Amazon region around 700 years ago, though their purpose is still unknown. So far, nearly 300 geoglyphs have been identified, but with advances in satellite imaging--and increased clearing of the jungle coverage--scientists are hoping to discover many more of these strange, geometric designs.
One of the factors that contributed to so many geoglyphs being undetected prior to the aid of satallites is their enormous size. According to leading geoglyph scientist Alceu Ranzi, his latest discoveries--five sets of geometric shapes, with circles, squares and lines--can measure more than a mile from one extreme to another.
You do not see them in field. There is a difference in the color of grass but is very thin. If there were no satellite images, there would be no possibility [of making these new discoveries].
Because they've been so hard to find, the first geoglyphs weren't discovered until the 1970s. Since then, scientists have been trying to piece together what significance they may have had to ancient Amazonians. What ever the purpose may have been, there's one thing that is certain: the ancient civilizations of the rainforest were more numerous and sophisticated than previously imagined.
According to a report from Globo, the new marks were only discovered because the jungle coverage had been removed to due to deforestation in the Amazon. These structures are deep, with grooves are as large as 12 meters wide and four deep, but it is believed that they were built when jungle abounded--which would make their construction all the more difficult.
Ranzi seems open to other possibilities:
Was it really forest [when the drawings were built] or did they occupy this area at a time of climate crisis, like that of 2005?
The world may never know what drove these ancient civilizations to carve the enormous geoglyphs, like the ones found recently using Google Earth. But, if it takes more clear-cutting in the Amazon rainforest to find out the answer, hopefully it will always remain a mystery.
Pretty amazing stuff especially how the ancient civilisations built these structures that made sense fully only from high in the sky - moreso how did the Amazonians know if the structures they built were accurate especially in the jungle when they didn't have the means to get up high enough to see above the forest?
Maths.
You can calculate it and then with relatively basic equipment make pretty accurate shapes.
Even within the dense jungle?! they must have been pretty advanced, Egyptians had massive open desert to work with easily but I'd imagine it to be extremely difficult in a crowded rainforest!
Impressive work though especially the sizes involved.
well as i read it they're only seeing them when the jungle is cleared so it's possible when they where made the jungle didn't cover those areas.
or they where done around the edges of large clearings which had been made for other uses.
Or they just cleared those huge straight lines did the digging then once they died the jungle reclaimed the trenches/mounds.
although looking at the size of that square in comparison to the road and the few single tress it's not that big.
looks about the size of a large cornfield.
Maybe way back when the places these things are were not dense jungle? Maybe it's grown/developed since then.
That's easily done with some sticks, some rope (twine. thread, whatever) and some basic maths.
Building things viewable only from above makes sense if those things have religious significance to you and you believe that your god(s) can see them from above.
That picture yeah but if you notice some of the glyphs found were up ot a mail across which is pretty huge considering lack of transportation back then :p
I did think about a "clearer" forest 700 years ago but then I remembered that the trees in the Amazon were most likely older than this anyway since the Amazon basin itself is around 55 million years old and according to the Wiki the first signs human inhabitance occurring some 11,000 years ago~?
But it's far easier to dig some trenches than it is to cut millions of tonnes of stone into millions of precisely shaped pieces, haul it all to the same location, precisely level a large area of land and build a precise pyramid that would be the tallest building in the world for over 3500 years (and then beaten only by a steeple that fell over).
You do not see them in field. There is a difference in the color of grass but is very thin. If there were no satellite images, there would be no possibility [of making these new discoveries...'
There's 'no possibility' that this would have been detected by aerial photography? Too much tree hugging has addled the brain. ;)
