OK so another idea I had. If you look back at the original mobile Stroker 12....
It had a rather nice big plate on the back. With stickers on. So, using modern techniques I want to make something similar. Annoyingly they did not have 5mm in the same gold, so I got an A3 sheet of that.
I mean in gold. Obviously sold out. I also got a A3 sized sheet in black.
Again in 3mm. Which will total 6mm or over (due to sheets never being exactly 3mm). This will be cut with a centre hole the size of the magnet plug OD, and then be the size of the magnet OD. Which I don't have access to as I am at home now. I will do that and machine them when I return.
Old iron is (or at least can be) really good. Can also be had quite cheap...you just need the room. To be honest, the most impressive thing about the Chinese lathes and mills is how good they are....given that the deeper you dive, the more 'wrong' they are. The fact they've taken so many shortcuts and still come out with something acceptable is quite astonishing.
