** THE FIRST MODDED GTX TITAN: GIGABYTE WINDFORCE 3X OC!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Gigabyte are bending the rules slightly with NVIDIA by not only offering an Overclocked Titan but one with a superior cooling solution as well. NVIDIA will not allow any modification to the Titan, hence why you only see Titans with stock NVIDIA cooler.
So Gigabyte are getting round this by shipping with their Titan the WindForce 3X cooler, the catch is you do have to fit it yourself, but they do provide instructions of course.
Anyway check it out here:-
Gigabyte GeForce GTX Titan OC 6144MB GDDR5 PCI-Express Graphics Card with 450W WindForce 3X Cooler @ £919.99 inc VAT
Welcome to the era of Supercomputer Gaming. With the DNA of the worlds fastest supercomputer and the sould of NVIDIA Kepler architecture, the Gigabyte GeForce GTX Titan GPU is a revolution in PC gaming performance.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
In the Kepler architecture, support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Features:-
- Bundle with WINDFORCE 3X 450W Cooling system
- Powered by NVIDIA GeForce GTX TITAN GPU
- Integrated with industry's best 6GB GDDR5 memory 384-bit memory interface
- Features Dual-link DVI-I/ DVI-D / HDMI / DisplayPort
- BASE:928MHz / BOOST:980 MHz
- System power supply requirement: 600W
Specification:-
- GPU: GeForce GTX TITAN
- Core Base Clock: 928 MHz
- Core Boost Clock: 980 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 3yr Warranty
Only £919.99 inc VAT.
ORDER NOW
This cooler should allow you to run the Titan at higher clockspeeds for longer, so with another 100mhz or even 150 maybe, the Titan will put the 780 back in its box.
Will they be selling these coolers separately or do you have to buy a Titan with them?
Thing is though anyone running a titan is probably running a decent custom loop so why would anyone spend an extra 160 quid over the msi titan when they could drop a block on for nearly half the price
