Hi there
We've had our first none reference 780Ti arrived, with the amazing more or less SILENT Phantom cooler:-
Gainward GeForce GTX 780Ti Phantom 3072MB GDDR5 PCI-Express Graphics Card @ £599.99 inc VAT
NVIDIA's latest Geforce 780Ti takes the fight right to the competition in the battle for current worlds fastest single GPU. Packing a fully enabled GK110 GPU with a whopping 2880 cuda cores this card has huge amounts of processing power to enable it to power through any game. Infact the 780 Ti is so impressive, it’s not just cheaper than TITAN, it beats it in performance and takes the crown as the Best Gaming GPU on the Planet.
NVIDIA are supporting the overclocking community even further with an advanced three rail PWM with load balancing, whereas older GTX 780 and Titan pulled all their power through three rails, they did not load balance. 780Ti's new PWM means it can source power from three sources and load balance resulting in the same amount of power from each rail, allowing for more superior overclocks and stability. Here at Overclockers UK we tested this and where we found Titans would top out at 1100-1150MHz core, whereas the 780Ti was able to hit 1200-1300Mhz core over and over again, proving this new PWM not only offers efficiency and stability, but also great overclocking ability. When overclocked this cards performance can be increased by upto a further 30%, making it a truly unstoppable force.
For memory once again here at Overclockers UK we are very impressed to see 3GB of RAM and a 384-Bit interface meaning it can power the latest games even at the highest resolutions and detail settings, making this card the perfect choice for any gamer or overclocker.
780Ti uses the Titan cooling system and this means that even whilst gaming, you can indeed game in silence or at night whilst the rest of the household is asleep and not have to worry about waking up those sleeping.
Specification:-
- GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 980MHz
- Core Boost Clock: 1046MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £599.99 inc VAT.
ORDER NOW
Specification:-
- GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
