I bought said tablet about 2 weeks ago and decided today to try and use it as SatNav in my car and neither Google or Apple Maps works.
With Google Maps the SatNav voice will give it's first direction and then nothing happens after that, the map does not move and I get no directions whatsoever.
With Apple Maps it just says "you current location cannot be determined" (or something to that effect. I've been all through the settings in the iPad and the two respective apps making sure everything to do with location is tuned on which it always has been.
Is there any kind of conclusive test I can run to determine if the iPad is actually faulty or not?
