The long road to data recovery! Help!
28 Sep 2008
Britain
Hi all,
In another thread, you'll see that the software raid S100 PERC controller failed in the Dell T110 2 server.
This was a simple RAID 1 of two 500gb disks.
I would have simply thought I could take one disk, mount it in another Windows machine and pull the data off. Apparently not.
At the risk of spending £200 on RAID RECOVER, which is unlikely to work, what else can I attempt to read this disk? Recuva doesn't even see it :( Well, it says it can't determine the file type, so not very helpful
Thanks
I would suggest trying to clone the disk first(if possible). It's weird as afaik raid 1 is just a mirror image so it should be readable as you said. Unless somthing more sinister has happened.
Where's this other thread I can't find it.
Are the controllers identical in the new machine?
have you tried just running a chkdsk, NTFS is pretty hard to totally screw up, controller probably jsut wrote some junk to the disk...
If you need to modify contents of a suspect drive, switch the Forensic ComboDock into temporary read/write mode.
Well that's a suspicious part of the sales pitch :D.
Wouldn't mirroring/cloning the drive do the same thing? It only reads not writes on the target disk doesn't it?
I wonder if it's due to the original controller being software based. Iirc software raid is rather finicky about being operated on anything other than an identical model. Ie another s100 perc controller.
The 2 new 1TB disks that are now in the server are performing beautifully.
There's an H300 PERC on order too and he's backing up to the cloud for now, but I really need this data off somehow...:(
I wonder if I could clone it to VHD / VMDK to mess about with it in a VM at some point.
I would double check with dell if it is a known issue but there are second hand s100s on the bay for £14inc. Not much for a trial run if needbe.
(As far as I can find there's only 1 s100 no revisions.)
