The max excpected OC with my hardware.
20 Oct 2007
South Yorkshire
I would like to know what the maximum OC i could expect to get without doing any upgrades on my comp, i try and find my max Oc until monday so i would like some of your thought first.
E2180 currently at 3.35Ghz
2Gb of geil ull PC2-6400 800mhz
asus P5E
ACF7
I was lead to believe that the E2180 was just as good at overclocking as the rest of the E21** range.
If i had the chip i would be dissapointed with anything under 3.5ghz, I would aim for 3.6 to 3.8 with a good cooler, anything above probably would have to be on water.
People have got 100% overclocks on the E2140/60 so can't see why the E2180 would be any different.
I cant see it running at 3.6ghz or more but i think i may have a go at getting 3.5.
Why not 4GHz - it's only 400FSB so the motherboard isn't going to be breaking a sweat and the low FSB/high multiplier means you should be able to do good things with lower volts than a Q6600 would need.
asus P5E
ACF7
You already have a very good overclock so anything else would be a bonus.
How did you get your Geil ULL 6400 to work with a P5E? Mine refused to do anything until i replaced it with Crucial Ballistix PC8500. It would'nt even load the OS.
I must just be lucky, i clipped them in and away i went :D
Are you sure it would be able to do that, if so what kind of temps would i be getting?
If the temps are fairly high i would add a tuniq tower in with my upgrade during january :)
:edit:
I wont be able to try the OC till monday (my last day currently staying in Tenerife :() and i may also need some help keeping my system stable on the forums :)
Can someone also link me to the version of coretemp that works in 64-bit vista
I thought I'd try - I can easily get into windows at 3.7GHz with 1.475V on. At 1.6V/400FSB/4GHz I could get my system to boot, but it won't boot into Windows.
http://valid.x86-secret.com/show_oc.php?id=288930
Now, I've just got this CPU and the AS5 isn't set up yet, but I'm idling at 33C on each core and hitting 60C under load with 1.475V at 3.7GHz. It's priming now, and I am using good custom water cooling and what I consider to be one of the best P35 motherboards - the Rev 1.0 Gigabyte P35-DS4.
Last time i checked i was running at about 24'C idle and around 50'C when stressed, i will have another look when i can. If i find that temps or my RAM is holding me back i'll ad some more goodies to my upgrade basket.
Currently it contains:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-026-OK&groupid=703&catid=17&subcat=510
So i have 250 left to spend however if i need some extra toys ill add the following:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-SB
http://www.overclockers.co.uk/showproduct.php?prodid=MY-093-CR&groupid=701&catid=8&subcat=817
I may also have a few Questions about WC'ing weescot :)
