- 27 Oct 2006
- London
[1] Hardware requirements
[2] Software requirements
[3] Attach to the milkyway@home project
[4] Install the GPU beta client
[5] *UPDATED* Multi GPU crunching !
[6] *OPTIONAL* Gaming on a multi GPU box whilst continuing to GPU crunch !
That should really be it, but things are never as smooth as they first appear to be. Typically I had Catalyst driver problems and had to uninstall, re-install and clean. Also I needed to kick in a lot of project updates and resets before it settled into crunching on the GPU.
Good Luck and don't forget to join the team
http://milkyway.cs.rpi.edu/milkyway/team_display.php?teamid=269
- ATI Radeon graphic card (HD3800 or HD4800 series, Firestream 9200 series)
- Catalyst 8.12, 9.1 - Catalyst 9.2 needs a tweak (see here)
- The latest version of BOINC
Currently using Catalyst 8.12 due to problems with 9.1. BOINC client is 6.6.12
Also please ensure that BOINC is installed as a service which is achieved by ensuring 'Protected Mode' is NOT checked during installation.
- Shut down ALL BOINC services
- Download the GPU client of your choice from http://zslip.com/
- Extract the files and copy to C:\Documents and Settings\All Users\Application Data\BOINC\projects\milkyway.cs.rpi.edu_milkyway
For Windows Vista use C:\ProgramData\BOINC\projects\milkyway.cs.rpi.edu_milkyway or wherever you specified the data directory to be during the BOINC install
- Restart the BOINC service and watch the credits roll in
Currently using version 0.19d for Win32_SSE2
- If you're slacking read on ....
- Multi GPU crunching actually works out of the box as of client 0.19d
- Shut down BOINC
- Disable crossfire from CCC
- IMPORTANT Enable a monitor on the secondary or tertiary card by extending or cloning desktops. Typically you need another monitor or use a dummy VGA adapter and that's it.
- Start BOINC and watch your GPUs get loaded to around 90% each
- Shut down BOINC
- For the slackers only ...
- Shut down BOINC
- Modify app_info.xml or write a batch script to toggle the following option ... <cmdline>x0</cmdline>. This implies that the client should NOT load work onto card 0 ie your primary card leaving it free to game or do whatever. The remaining cards will continue to crunch
- Restart BOINC.
- Slackfast
- Shut down BOINC
- Restart BOINC.
- Slackfast
Yeah I screwed up the title and I can't change it either.
I don't have an ATI card.
