Bought a standard rev 3 MR2 turbo last year. Had it 4 months before detonation killed one of the pistons.
Rebuilt it with this turbo
And promptly cracked the block.
Have just had the block back from being sleeved and the head is away to get modified now also. Here are a few shots of the engine and BMIC before I tore it down again. Apologies for poor quality- its a nokia E51
Car is entirely home built, apart from the machine work to the block and head!
Spec is
2.0 3SGTE with CP Pistons and crower rods
ACL race bearings
ARP everything
Rebalanced crank
Totalseal gapless top ring set
1000cc injectors
AEM EMS (Had link G3 on last build, but it was too basic for my needs)
Garrett GT3582 turbo
30x12x4'' Boot mount intercooler
in tank walbro 255 lph pump
external Bosch 044 motorsport fuel pump, feeding swirl pot mounted in boot
aeromotive fpr
HKS 264 exhaust and 272 inlet camshafts
Fidanza vernier pulleys
Big valve head, ported and gasflowed, and gasket matched
Sleeved block
RPS 525 lb/ft clutch
HKS head gasket
OEM gaskets & belts
Home made downpipe & screamer pipe (I can TIG quite well thankfully)
Tial 38mm wastegate with CNC machined turbo adapter plate on stock exhaust manifold
Monster K&N air filter
lightened flywheel
Rebuilt gearbox with cusco 2-way LSD
CRW Inner CV joints
HiSpec brake calipers all round
Cusco zero-2 coilover suspension (FAR too stiff!!)
Im waiting on a JUN style inlet manifold and enlarged TB. Once I get that I will hopefully have the head back also and ready to try for some big numbers!
few shots
Spec is
ACL race bearings
ARP everything
Rebalanced crank
1000cc injectors
aeromotive fpr
Sleeved block
HKS head gasket
OEM gaskets & belts
lightened flywheel
CRW Inner CV joints
few shots
