The OcUK Sandra Performance Index Thread
rjk
rjk
OcUK Staff
8 Aug 2007
after using this program for a while i decided to make a thread to chart system performance of OcUK forum members
the 3d benchmarks can stay in the graphics section... :eek:
this should give a broad spectrum of system speed rather than how many FPS you get with 3D performance
this benchmark rates the CPU, Memory and HDD performance
you can download the software for free here
[it includes a load of other useful tools aswell]
all you need to do - is run the program...
go to the 'Tools' tab
and click - Performance Index
leave your PC for 15 minutes and it will have a performance index for you
upload a screenshot of the index page along with your score
in this format:
SCORE: 1000
SCREENSHOT:
if you wish you can use the 'copy to clipboard' button at the bottom left of the results page to paste a breakdown of your results into your post
if we get enough results then i will do a leaderboard
good luck! :)
here is mine...
SCORE: 1104
SCREENSHOT:
SiSoftware Sandra
Display on Screen
Connection : Local Computer
Processor Arithmetic
Analysing...
Combined Index : 88964MOPS
Run ID : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C, HT, 4GHz, 49% OC, 3.20GHz MC, 4x 256kB L2, 8MB L3)
Finished Successfully : Yes
Processor Multi-Media
Analysing...
Combined Index : 179021kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 26.73GB/s
Run ID : Intel X58 I/O Hub; 3x 2GB Corsair DIMM DDR3 (1.60GHz, 19% OC) PC3-12800 (6-8-8-24 6-32-4-8)
Physical Disks
Analysing...
Combined Index : 160.62MB/s
Run ID : Intel Raid 0 Volume 1TB (SATA9600, 32MB Cache, 1GB Flash)
Performance Index
Combined Index : 1104 (total)
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 94994MOPS
Run ID : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C, HT, 4GHz, 2x 256kB L2, 8MB L3)
Analysing...
Combined Index : 509819it/s
Memory Bandwidth
Analysing...
Combined Index : 23.15GB/s
Run ID : Intel QuickPath Architecture I/O Hub to ESI Port
Physical Disks
Analysing...
Combined Index : 169.17MB/s
Run ID : Intel Raid 0 Volume 600GB (RAID)
Network (LAN)
Analysing...
Combined Index : 12.37MB/s
Run ID : Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport (Ethernet, 1Gbps)
Performance Index
Combined Index : 16899 (total)
i thought i was missing the network one!!!
will reupload - nb to all - dont use a wireless adapter - you need your ethernet cable plugged in
Q6600 @ 3ghz; Corsair XMS3 1333c9DHX; ASUS Striker II Extreme
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 42671MOPS
Run ID : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4C, 3GHz, 25% OC, 2x 4MB L2, 1.33GHz FSB, 24% OC)
Analysing...
Combined Index : 96664kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 6.46GB/s
Run ID : Nvidia 0800h; 2x 1GB Corsair DIMM DDR3 (1.33GHz) PC3-10700 (9-9-9-24 5-34-10-5)
Physical Disks
Analysing...
Combined Index : 82.45MB/s
Run ID : SAMSUNG HD642JJ 640GB (ATA, 3.5", 7200rpm, NCQ, 16MB Cache)
Performance Index
Combined Index : 436 (total)
N.B. I'll post some 3.6ghz benches later
Score 1055
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 78674MOPS
Run ID : Intel(R) Core(TM) i7 CPU 940 @ 2.93GHz (4C, HT, 3.52GHz, 20% OC, 2.56GHz MC, 4x 256kB L2, 8MB L3)
Analysing...
Combined Index : 157496kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 17.54GB/s
Run ID : Intel X58 I/O Hub; 3x 2GB DDR3 (960MHz) PC3-7700 (7-6-6-18 3-24-4-3)
Physical Disks
Analysing...
Combined Index : 238.96MB/s
Run ID : Intel Raid 0 Volume 64GB (RAID)
Performance Index
Combined Index : 1055 (total)
What version of the software should I be using?
The latest? What happens if they change the version, won't it be difficult to compare like for like?
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 211777MOPS
Run ID : 4x Intel(R) Xeon(R) CPU E7450 @ 2.40GHz (6C, 2.40GHz, 3x 3MB L2, 12MB L3, 1.07GHz FSB)
Analysing...
Combined Index : 547625kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 7.90GB/s
Run ID : Intel 7300 Memory Controller Hub; 4x 16GB Samsung DDR2 FB-DIMM (668MHz) PC2-5300 (5-5-5-15 0-20-5-9)
Physical Disks
Analysing...
Combined Index : 68.52MB/s
Run ID : HP LOGICAL VOLUME 147GB (RAID, 15000rpm, NCQ)
Performance Index
Combined Index : 1132 (total)
Memory seems to be letting this one down - appears to be misreporting anyway - only showing 64GB of memory (from 128GB )
Does this sound right:cool:?
Idle CPU temp 42°C GPU 51°C
Full stress CPU temp 59°C GPU 72°C
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 78717MOPS
Run ID : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C, HT, 3.52GHz, 31% OC, 2.96GHz MC, 4x 256kB L2, 8MB L3)
Analysing...
Combined Index : 156840kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 24.12GB/s
Run ID : Intel X58 I/O Hub; 3x 2GB OCZ DIMM DDR3 (1.48GHz, 38% OC) PC3-11800 (7-10-10-24 6-34-4-8)
Physical Disks
Analysing...
Combined Index : 52.48MB/s
Run ID : SAMSUNG SP2504C 250GB (SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
Video (GFX) Rendering
Analysing...
Combined Index : 28724239kPixels/s
Run ID : 2x NVIDIA GeForce GTX 295 (896MB, 1.24GHz, PCIe 2.00 x16, SM4.0)
Performance Index
Combined Index : 9873 (total)
I need an upgrade...
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 22869MOPS
Run ID : Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz (2C, 3.22GHz, 73% OC, 2MB L2, 1.84GHz FSB, 72% OC)
Analysing...
Combined Index : 43070kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 5.26GB/s
Run ID : Intel P35/G33/G31 Processor to I/O Controller; 2x 1GB Corsair DIMM DDR3 (1.10GHz) PC3-8800 (7-7-7-24 12-31-12-12)
Physical Disks
Analysing...
Combined Index : 86.26MB/s
Run ID : SAMSUNG HD103UJ 1TB (SATA300, 3.5", 7200rpm, NCQ, 32MB Cache)
Analysing...
Combined Index : 126162kPixels/s
Run ID : NVIDIA GeForce 8800 GT (512MB DDR3, 557MHz/1.29GHz/2x900MHz, PCIe 2.00 x16, SM4.0)
Performance Index
Combined Index : 379 (total)
Edit: I have the biggest % OC by far though, so I'm awesome.
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 30819MOPS
Run ID : Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2C, 4.05GHz, 35% OC, 6MB L2, 1.8GHz FSB, 35% OC)
Analysing...
Combined Index : 57543kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 7.83GB/s
Run ID : Intel P35/G33/G31 Processor to I/O Controller; 2x 2GB Corsair DIMM DDR2 DDR3 (900MHz, 12% OC) PC3-7200 (5-5-5-12 4-17-8-5)
Physical Disks
Analysing...
Combined Index : 73.18MB/s
Run ID : SAMSUNG HD502IJ 500GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Analysing...
Combined Index : 79923kPixels/s
Run ID : ATI Radeon HD 4800 Series (512MB, PCIe 2.00 x16, SM5.0)
Performance Index
Combined Index : 413 (total)
Done some more tweeking
I have run the test after some tweeking and removing of the video scores....this is what I get
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 84341MOPS
Run ID : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C, HT, 3.78GHz, Turbo, 34% OC, 3.60GHz MC, 4x 256kB L2, 8MB L3)
Analysing...
Combined Index : 168559kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 25.33GB/s
Run ID : Intel X58 I/O Hub; 3x 2GB OCZ DIMM DDR3 (1.44GHz, 35% OC) PC3-11500 (7-10-10-23 6-33-4-8)
Physical Disks
Analysing...
Combined Index : 90.93MB/s
Run ID : ST3500418AS 500GB (SATA300, 3.5", NCQ, 16MB Cache)
Performance Index
Combined Index : 928 (total)
Everything is running better then before!!! w00t!!
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 94.99GOPS
Result ID : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C, HT, 4.2GHz 49% OC, Turbo, 3.2GHz IMC, 4x 256kB L2, 8MB L3)
Analysing...
Combined Index : 188.27MPixel/s
Memory Bandwidth
Analysing...
Combined Index : 27.44GB/s
Result ID : Intel X58 I/O Hub; 3x 2GB Corsair CM3X2G1600C7 DIMM DDR3 (1.6GHz) PC3-12800 (9-8-8-24 6-32-14-8)
Physical Disks
Analysing...
Combined Index : 56.34MB/s
Result ID : SAMSUNG HD501LJ (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Video Rendering
Analysing...
Combined Index : 190.00MPixel/s
Result ID : ATI Radeon HD 4870 X2 (2x 800 SM5.0 750MHz, 2x 1GB DDR5 4x900MHz, PCIe 2.00 x16)
Performance Index
Combined Index : 995 (total)
SiSoftware Sandra
Display on Screen
Analysing...
Combined Index : 31192MOPS
Run ID : AMD Phenom(tm) II X3 720 Processor (3C, 3.21GHz, 2.61GHz MC, 3x 512kB L2, 6MB L3)
Analysing...
Combined Index : 89089kPixels/s
Memory Bandwidth
Analysing...
Combined Index : 14.68GB/s
Run ID : AMD (ATI) RD780 GFX Dual Slot; 2x 2GB OCZ DIMM DDR3 (1.34GHz, 25% OC) PC3-10700 (6-6-6-24 5-33-9-5)
Physical Disks
Analysing...
Combined Index : 47.88MB/s
Run ID : WDC WD4000YR-01PLB0 400GB (SATA150, 3.5", 7200rpm, NCQ, 16MB Cache)
Analysing...
Combined Index : 93049kPixels/s
Run ID : ATI Radeon HD 4800 Series (1GB, PCIe 2.00 x16, SM5.0)
Performance Index
Combined Index : 516 (total)
Well this is so bias lol
For instance no everyone will be useing the same version
2nd you havent stated a resolution to be running in when you run the test as the video test uses your desktop resolution for instance mine 1920x1200 where as others could be lower or higher.
also for the life of me i cant get the lan option to work
and i also cant get the program to test my fastest hdds it tests my slowest hdds lol
so meny things that could influence peoples scores in this test.
i wouldnt bother. imho
