- 1 Dec 2015
Strix-ly beQuiet!
Whilst I await the completion of the Zotac block scanning and then the 2 month wait for the block to run off the experiment, thought i'd get to grips with the UMX3 case.
Introducing ;
100% ASUS ROG and beQuiet Themed project build.
Parts List
Intel i5 6600k/ i7 6700k- Ordered
Asus ROG Z170 Gene viii - Ordered
ASUS STRIX GTX 1070 8GB - Ordered
Samsung Polaris 256GB - Ordered
Seagate SSHD 1TB - Ordered
Kingston FURY Black DDR 4 2444hx 16GB - Ordered
beQuiet Pure Power 9 600w - Ordered
CoolTek UMX 3 Window Black - Ordered
NZXT Hue+ - Ordered
beQuiet Silent Wings 3 120+140mm - Ordered
Alphacool Eisbaer 120 (Silent Loop not out yet) - Ordered
Total Build £1305
This Build was due to feature a GTX 1060 Strix in the UMX1 Plus mITX case, but was given official clearance measurement of 125mm for the max height of a GPU, the 1060 STRIX is 129mm and would have used ASUS's B150i Aura board.
I did see the exact or chinese version of the Strix cooler in this case, it would fit just with the removal off one of the panel pins but the heat was just to much for the system to run well. This lead to the jump up to the mATX version of the case, that soon spiraled into GTX 1070 and then the jump to the Z170 chip.
Keeping the case cool will be handled by BeQuiet Silent Wing 3 fans, 140mm up top set to 100% (as the PSU expels hot air to the top of the case then is drawn out) since its so quiet. 120mm will be also acting as an exhaust but will cool down the i5 6600k using Alphacools Eisbear AIO, in push. Unfortunately beQuiet's Silent Loop isn't out till 4 weeks time (made by Alphacool), hence the Eisbaer.
Im half tempted to utilise the Strix fan headers by controller fans at the bottom of the case since there's a giant filter on the bottom of the case. Although there is not actual fan mounting points, will just use a PCIe fan bracket and have two 80mms to push some cool air towards the GPU and top of the case.
FYI max card length in case is 320mm with PSU being 160mm including cables. Strix is 290mm and True Power PSU is 150mm so should be tight!
Handling the lighting will be the Hue+ , should light up the case nicely with 3 strips around the case edges and one under the Gene on the right hand to give an underglow.
Introducing ;
Parts List
NZXT Hue+ - Ordered
Total Build £1305
