- 24 Oct 2002
- Portsmouth
With my current Q6600 I've been overclocking it and discovered something I think of as it's overclocking wall. To explain I have a Q6600 which happily runs at 3.5gig, 1.375 volts and max temps of 68 degrees under Prime95 load.
It runs Prime95 all day and is an excellent performer.
Now if I try and set it to 3.6gig, just 100Mhz more it needs substantially more voltage, as much as 1.45v and the temps sky rocket to 77 degrees. Under these conditions it can BSOD. Adding extra voltage beyond 1.45 doesn't really help as I think it's the heat that kills it.
It weird, a mere 100Mhz difference and yet it's like the difference between night and day for stability and heat generated.
I usually choose the stable speed when I find my processors 'wall'. What do the rest of you do, the same? Buy water cooling?
