Having just done a pile of reviews a lot of which have been fns it got me thinking
What would be the perfect fan.
Not looking for shed loads of numbers here, just feelings and instinct
So What would be your perfect fan? Think....If I could have the looks of fan X and the performance of Fan Y what would you choose.
My starter for 10 would be
Performance of Scythe Gentle typhoon, but with a 2400rpm model
Gloss black cowling, with the metal band from the Enermax range.
Central Hub mounted LEDs as per the AP range (very nice even light distribution).
So what's your ideal fan.
In all honesty I'm pretty satisfied with my Apaches both looks and performance wise.
. Noiseblocker multiframe M12P or PS. 2000rpm, slightly more static pressure than a GT, and 120+ cfm. At full 2000rpm I think they go up to 28db, pretty much silent under 1200rpm. That's if you can afford to get a full set for your rads...
