** THE PHANTEKS ATX CASE THAT YOU'VE ALL BEEN WAITING FOR **
OcUK Staff
26 Nov 2014
Stoke
The Enthoo Pro in Titanium Green of course! What, you were expecting something else?
Phanteks have decided to launch their popular pro model in Titanium Green. It looks pretty nice in the flesh, and offers something a little different to the usual case colours that we have been accustomed to seeing. Stock should be available by the end of June.
Regarding another ATX based Phanteks case launch, keep your eyes peeled :)
Phanteks Enthoo Pro Mid Tower Case with Window - Titanium Green @ £89.99 inc VAT
Beautifully crafted and engineered to maximize cooling potential with its amazing expansion flexibiltiy, the Enthoo Pro is the budget friendly mid-tower from Phanteks. Embracing many features from the Enthoo Primo and Luxe, without the price tag. This case has mulitple radiator support, removable ssd bracket, closed HDD panel, and velcro cable management. The Enthoo Pro, trying to establish its own solid reputation like the award winning Enthoo Primo.
The Enthoo Pro is designed to house the most formidable gaming systems on the market today. Design is paramount as ever and the Enthoo Pro retains the clean elegant design from the Enthoo Primo. Finished in a high quality brushed aluminium appearance and paired with a stealthy interior design, the Enthoo Pro is a gaming chassis that surpasses rivals and offers much more to the hardware enthusiast.
Functionalities and Cooling:
- Dual repositionable and removable harddrive cages
- Closed HDD panel
- Removable Drop-N-Lock SSD bracket
- Fully equiped with dustfilters (1x top, 1x front, 2x bottom)
- Clean cable management using Phanteks’ pre-installed Hoop-N-Loop cable ties
- MOD friendly structure - fastened by screws instead of pins
- Removable Reservoir Bracket
- High cooling capacity (capable of housing 8x 120mm fans / 7x 140mm fans / 2x 200mm fans)
- Comes with 2 Phanteks premium fans 1x 200mm in front & 1x 140mm in rear
Watercooling Support:
- 4 different installation areas for single to triple radiators
- Reservoir mounting points
Specification:
- Dimension 235 mm x 535 mm x 550 mm (W x H x D)
- Form Factor Full tower
- Material(s) Brushed plastic, Steel chassis
- Motherboard support ATX, EATX, mATX, SSI EEB
- Front I/O 2x USB 3.0, 2x USB 2.0, Mic, Headphone,
- Side window Yes, split-window design (optional closed window sidepanel)
EXPANSION & DRIVE BAYS
- Expansion slots 8
- External 5.25” 3
- Internal 3.5” 6 (2x 3HDD cages)
- Internal 2.5” 7 (1x SSD bracket)
COOLING 120mm fan 140mm fan 200mm fan
- Front 2x 2x 1x (included)
- Top 3x 3x 1x
- Rear 1x 1x (1x included)
- Bottom 2x 1x
- HDD cage 2x -
LIQUID COOLING 120mm radiator 140mm radiator
- Front Up to 240 -
- Top Up to 360 Up to 420
- Rear 120 140
- Bottom Up to 240 140
CLEARANCE
- Graphic card 347 mm (without HDD cages 472 mm)
- CPU cooler 193 mm
- Cable management 27 mm (39 mm at PSU area)
- Radiator (TOP) 65 mm to motherboard
- Colour: Titanium Green
- Warranty: 5 Years
Only £89.99 inc VAT.
ORDER NOW
