The Red Machine
Man of Honour
21 May 2012
Dalek flagship
The Red Machine.
This is going to be a rebuild of my AMD PC hence the name and the other reason for the name will be apparent when you see the case I am using.:)
Parts List.
LD V8 case (Black/Red).
Asus RVE X99 Motherboard.
5960X CPU.
Build Pictures.
You guessed it, red enough to keep even Leon Trotsky happy.:D
Fitting the PSUs
The two rads that will go in the bottom of the case.
And the one for the top as well
Case is amazing looking Kaap. Yes red and black is a very common theme, but no matter how many such builds i see, they just look right.
I have found running the cables under the rads keeps them out the way.
