Man of Honour
- 29 May 2004
- Tall building nearby
Had the ring of death problem today and got onto MS they sorted out all the details ect for the pickup under warranty then just out of curiosity turned it on to see if I left a disk in before I unplugged it all ready to be sent away and the dam thing decided to work. So what do I do? send it off or not cant decide. I had allready tried and checked all the cables and everything before I called MS and it still would not boot just gave the three red lights, the furthest it did get was displaying about half ther intro screen. Then I sort it all out to be repaired and it resurected its self?. Anyone had same thing happen?.
I use it on a component cable for HD and it has two controllers and a memory card never got around to getting a hdd as I dont use it that much got one of each in this generation of the consoles and the other two get used more. It will work with any of the controllers or memory card plugged in or all at the same time so I cant see it being those that caused the red lights.
