The Saboteur help
6 Mar 2008
Stoke area
Hey,
Anyone played this that can tell me if it is possible to view the map?
You see a mini map on the play screen, you see a small area of a map when you press escape but I can't find anything anywhere about an actual map in the game.
Tried all the keys, nothing in the options and google throws up nothing :(
nice one, yeah, i'm going to blame the tiredness :( :p
As for the game, if you can pick it up for under £5 it's worth it. Very much feels like a console port, can't find anyway of changing res, car controls are very bland and I would advise playing it on a hard difficulty.
There's lots to do, but doesn't feel like it has any effect on the game, for instance there are search lights, sniper towers, radar stations etc you can blow up throughout the map, but it feels more like a "what can we do to pad the game out" afterthought than anything else.
Story has seemed very easy to follow so far and is pretty good for what the game is. I'll play to finish and see if it gets any better, but it defo feels like a early 2000 game and not one developed in 2009.
One issue I had with the map was the icons don't seem to scale with the map when you zoom in and out, so they end up being in the wrong place.
You can definitely change the resolution, although I found I had to set it to 60hz.
Taking out the towers etc I believe contributes towards removing Nazi oppression i.e. making the colour palette for that area change from B&W to coloured, but my memory is a little hazy.
I wrote a mini-review here: http://forums.overclockers.co.uk/showpost.php?p=23436478&postcount=151
