- 26 Sep 2005
- Tonbridge, Kent
For a while now i have been contemplating upgrading my 17" Crt monitor to a 19"-20" TFT.
However after much research i have come across several problems.
1. Native resolutions - Depending on the size of the monitor/brand etc the native resolutions differ. At 1280*1024 would be ideal for games, but not really good if i wanted to run them at higher resolutions in the future.
1600*1200 is great for photo editing and level design (which i do quite a bit of) but not for running games. If i rescale quite often a lot of detail is lost.
Have any of you had any problems with up/down scaling the resolution on your tft's?
2. Gaming performance - Quite a few of the reviews i've read concerning a lot of TFT's seem to suggest that some TFT's are good for gaming (Very little blurring/ghosting) but have bad colour (which is bad because as i've said i do a lot of photoshop and printing)
3. Bad pixels - I've looked through a list of all the companies detailing what their attitudes are to dead pixels (i.e. replacements) For BenQ, your TFT literally has to be completely covered with dead pixels before they will exchange, not sure on OCUK's stance on returns?
4. Lastability - I've had my monitor for years, I need something that will perform even after excessive use.
I want a large TFT but it seems a better bet to get a large CRT which can display a good picture at almost any res with very little ghosting.
What is everyone else's opinions?
