Been looking around and there's a fair amount of KVM over cat5 extenders
There's also IP switches where you can control several over a front end (it basically end up looking like terminal services but it's a hardware solution so works even if the machines screwed and can't boot etc, called a console in the IT industry)
Was wondering if theres a combination of the 2?
Would like to take monitor/keyboard/mouse into a box, over a network and into my PC in another room. Basically for a little light gaming in the comfort of my living room. With the mass of options for the 2 above finding something that specifically does this is proving tricky. The first option isn't quite viable as it requires a dedicated patch cable between source and remote control. I basically need the first over IP though. Anyone know anything of it?
In before any "omg thats sooo not possible" we can play WoW on a cellphone via GPRS (thin client, sending inputs to a proper logged in PC and showing you the display), yes not in an IMBA way but it works, i'm after something that's not a lightyears step up from this.
