The tips and advice thread
19 Sep 2007
Ok so here is the idea just add in any tip or useful bit of information you find is interesting or that you do which might help someone out.
This can range from simple DIY to cookign or what ever!
Here is my tip,
"If you have bread that is prone to breaking when being buttered using a knife try using the underside of a spoon instead it spreads the weight and tends not to break the bread"
NEXT!
Aero
Here is my tip,
NEXT!
Aero
I tried it and it broke the bread! My tip is ignore Aero!
Never under any circumstances rub Vick on your chest and then scratch your nut sack :eek:
never put off getting a new tyre put on your car after a puncture, its guaranteed that you will get another puncture within a week of the first.
