Ok bear with me. This isn't from my machine. I sell quite a bit of used hardware and generally deliver it personally. Occasionally I also trade items if they are financially in my favour.
Anyway...
I arrive at guys house ready to trade an EVGA 650GQ PSU for a PNY 1050ti. He states that he's just purchased a GTX 1660ti XS OC Ventus as he believes his Corsair VS550 PSU is causing his 1660ti to not output any display or be recognised by his board. There is no issue with the PNY 1050ti when installed on the board (note: it has no ext 6/8 pin power connectors and just uses the 16x PCIe slot).
Before I go on I should probably list his and my hardware which is present.
i5-8400
Corsair Vengeance 16GB DDR4 2666Mhz (2x 8GB)
Gigabyte B360M H MATX Motherboard
PNY 1050ti 4GB
MSI 1660ti Ventus 6GB XS OC
(mine) EVGA 650GQ 650w PSU 80+ Gold
Corsair VS550 550w PSU 80+ (not bronze, silver or gold)
I think his logic is fairly sound and he's used a process of elimination to figure out the VS550 is most likely at fault by failing to provide enough power (or is faulty) for the GPU and thus it isn't detected by the motherboard at boot and thus no display.
We switch out the VS550 to the EVGA 650GQ, install the 1660ti and still no display. The motherboard however is now displaying via the IGFX through HDMI whilst the 1660 is installed. Weirdly (no matter which PSU is used) no GPU is detected as being installed on the board.
(I should say at this stage the board BIOS was up to date)
BIOS reset...
Still nothing...
Over the course of an hour various BIOS options are switched on and off including turning off all additional power settings, forcing output to the PCIe slot, disabling IGFX, varying the Gen tech for the PCIe slot - everything in every section is tried. Still no display.
The board, gpu, psu, ram, cpu etc are removed from the case and placed on a box - still no display.
Then in a moment of madness we connect both PSUs. The EVGA 650GQ remains connected to the board 24pin + 8pin and the VS550 is connected solely to the GPU 8pin and pins are bridged in the 24pin connector to power it on manually. The VS550 is powered on first and the board is powered on second.
Display!!
Display is now output from the 1660ti and it is recognised by the board in the 'plugged in devices' section. Returning back to a single PSU configuration gives no display output. Switching back to a dual PSU configuration gives display output. The process is repeatable.
I've never seen anything like this before. What is going on as I'm at a complete loss?
Some theories:
a) There is a fault with the board.
b) Power isn't being supplied to the GPU quick enough when the board is powered on and thus there is no output display.
c) The use of the 1050ti with no additonal power connectors has damaged the PCIe x16 slot.
d) The GPU requires some sort of BIOS update.
e) The board requires some sort of BIOS update.
Any light on this would be much appreciated as I'm curious to understand what is going on/wrong.
Many thanks
Anyway...
i5-8400
PNY 1050ti 4GB
BIOS reset...
Still nothing...
Display!!
Some theories:
Many thanks
