The Witcher help needed please...
14 Sep 2007
Limbo
Right, i've just installed The Witcher, registered the game and downloaded the Enhanced Edition patch. But when I go to install it I get this message...
"The language pack corresponding to the language version of the game already on your system was not found. Download the relevant language pack"
Where do I get the language pack? I did download TWEE_English_language_pack but it says the enhanced edition needs to be installed first...at a bit of a loss here :(
You need to put both the language pack and the uprade in the same folder then start the upgrade.exe it should work then.
even though my downloads go into the same place I still needed to put them in empty folder for it to work.
hope that helps.
Remember not to end the process even if one of the task's seems to have the (not responding) as it still should be working. if you do end it you will have to re-install the game from scratch again.
I did have this game last year but it wouldn't run at full specs with my 8800gt and amd2 dual core...this was a game I really wanted to wait until I had a system to play it in all it's graphical glory. I think my X3 Phenom @ 3.4Ghz and 4870 1GB should obliterate this now :D
Spent the last 15 minutes uninstalling then re-installing...didn't make a difference.
This however worked, many thanks :D
EDIT: "Modifying game files, this may take up to two hours"
/me bangs head on desk!
Just completed...about to update my catalyst drivers, haven't done that in about 5 months...then off we go.
Oh hang on...gotta get patch 1.5 now, he he!
All setup and running, played 10 minutes of it, as I thought, settings all maxed out in full graphical glory. Play style is a little different to what i'm used to but sure it will click into place. Now just need a week off work ;)
If you get stuck again the official forums are a great resource. Enjoy it; best game in years. Blissfully, unpolluted by console crap.
So unpolluted that the Witcher on the consoles got cancelled due to lack of funds lol. Luckily they are still working on the sequel for PC =D
Been playing for about an hour and this game is growing on me at an immense write, it's simply awesome!
Yep it is an awesome game. I haven't finished it yet. I stopped playing ages ago. I really ought to go back and finish it off as I really enjoyed it when I last played it.
I found it really bad the first few hours of the game. But got better a few level ups in.
It can be tricky early on; most people get to "The Beast" and tear their hair out. That bit is overly hard, IMO, but the rest of the ride makes the effort well worth it :)
I just wish it had a bit more variation, for re-play purposes. Still, after five or six runs, I've had my money's worth.
