The Witcher - its doing my head in !!
7 Nov 2002
pantyhose factory
Picked up the witcher for 3.50 on steam sale, started playing, control system is ludicrously annoying. It makes me want to ram my fist into the monitor and go on a spine snapping spree.
Is it just me or is the control system actual pants ?, is there anything you can do to improve this or is it just a case of grin and bear it and eventually you get used to it ?
Stick with it, the combat becomes much easier once one you're used to the control system, it took me a while too, but eventually things clicked and I really enjoyed the game from there on.
I ended up using an xbox controller for mine, felt a lot better in terms of controls.
I found it annoying at first, but after finishing the game i ended up thinking that the controls are actually one of the games biggest strengths. You know you can choose between different camera angles? I prefer over-the-shoulder view to isometric tbh.
Combat is actually quite brilliant once you get in to it imo.
I don't know what people get so annoyed about with The Witcher's combat. It's not particularly hard - click, wait, click, wait... wait, click. Oh, look that's not doing too much damage. Pause. Switch stance. Unpause. Click, click.
Oh crap, use a bomb.
It's simple, but effective.
I assume OP is not using over the shoulder OTS view.
Because OTS view is perfect in The Witcher, control-wise.
This is how I played the game - it's by far the best method for exploration and taking on small numbers of enemies. You can always zoom out to a tactical view if you're being swamped by a large number of enemies.
