***** THE WORLDS FASTEST AIR-COOLED GTX 780 IN STOCK AT OcUK: KFA2 GTX 780 LTD OC HOF WHITE EDITIO
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As with all KFA2 White LTD OC / HOF cards OcUK has the European exclusive, though you can also find this card available from our sister company www.caseking.de in Berlin, Germany.
This is currently the worlds fastest air-cooled GTX 780, even beating the EVGA Classified and is designed purely for overclocking. The price is also extremely good for a card of such calibre:-
KFA2 GeForce GTX 780 LTD OC 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE HOF** @ £575.99 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £575.99 inc VAT.
ORDER NOW
Titan beating performance for far less money! :D :D :D
Alright Gibbo, you win :D Ordered :D now please stop it with these deals, my wallet can't take it anymore!
Ianh, what do you think to the card? If you don't mind me asking?
**EDIT** sorry for the double post, ive no idea how i did that!
Hi there
Yes be good to have some Feedback, especially on overclocking, were finding People with MSI Lightnings are hitting around 1300-1360MHz with the stock cooler and 1400MHz plus on H20, so be good to here what People are hitting with Classifieds and the KFA2 Card. :)
I'm hitting 1306Mhz on the GPU but the memory doesn't like much OC'ing, only running 1575mhz before stability issues (driver fails) when it should be able to hit 1700+. However, even stock (1006/1502mhz) it's still plenty of power.
If I had the money to spend again TBH I'd have waited for the MSI Lightning.
Still a great clock and core clock is more impOrtant than memory clock
MSI lightnings aren't much better for overclocks on the memory as they use the same chips.
I got lucky as mine hits 6900. I've got it at 1306/6900 for gaming and have hit as high as 1407/6900 in benches (Valley) on a suicide run :p.
