I'm changing configuration of the DVD-Video playback on my HTPC.
For AVI's I use FFDSHOW to resize to 1680x1050. For 4:3 material it's stretched correctly so there's borders on the left and right, with no borders on the top and bottom.
TT is set to use FFDSHOW as the post processing. Auto Aspect ratio to off.
When I play a DVD (I had to install My Movies plugin) a widescreen DVD isn't stretched fully, there are borders on all four sides.
How can I correct this?
Also I have the Microsoft MC remote, some buttons work, but I have a few discrete codes from the built-in Home Theatre Master MX-700 database. These worked with Power DVD 7, but they don't work in TT (Audio and subs)
How can I correct this?Also I have the Microsoft MC remote, some buttons work, but I have a few discrete codes from the built-in Home Theatre Master MX-700 database. These worked with Power DVD 7, but they don't work in TT (Audio and subs)
