Theory Test
Good luck, don't worry the questions were the easiest test i have ever done. Just be carefull not to slip up on the hazard bit (i found this easy, but if you havent practised once or twice i could see it being difficult)
gam3r said:
Hope it all goes well and you get what you deserve! ;)
Cheers - I'm pretty confident but you never know.
Been through about 900 multiple choice questions on the DSA learning program disk - I was assuming they're the same pool of questions that are used in the exam but not 100% on that. Anyone know for sure?
They do ask the same pool of questions, but some of them may be slightly updated with different wording/pictures. :) Mine were pretty much the same as the CDrom i had!
