Thermal compound, quick question
22 Aug 2005
Kent
My e8400 has just arrived. Being new to pc building I'm not sure whether I need thermal compound or not? The heatsink it came with looks like it has some grey striped stuff on it already, is this thermal compound that it comes with?
At a later date I plan on overclocking a little, will I need it for this?
The gray strip is the thermal paste, if you do remove the cooler in the future you will need to use fresh compound.
you really only need to use your own paste if you plan on overclocking and in that case your going to have to get a 3rd party cpu cooler anyway, so best just use the stock cooler and paste just now and it can be easily upgraded in the future.
Kenny
