Thermal Compound - Which of these to use
31 May 2005
Alfreton,Derbyshire
I have a few left over tubes from previous builds. This will be used on my 2700k
IC Diamond 7 Carat
MX-4
Artic Silver 5
Artic Silver 3
I used the IC Diamond last time around and just used the small pea size blob in the middle and let the HS spread it. Which should I go for, I'm tied between using the IC and MX-4 same application method for each. Small blob has always worked fine previously.
Cheers,
Havent used the ic diamond stuff, but always been pretty impressed with mx-4. Non conductive and easy to apply.
