7 Mar 2006 at 00:36 #1 Fireburst Fireburst Associate Joined 2 Feb 2006 Posts 64 Is the thermal compound that comes with a big typhoon ok to use or should I use the Arctic Silver 5 that I have?
7 Mar 2006 at 00:52 #2 Ladforce Ladforce Associate Joined 17 Feb 2006 Posts 898 Location Fleet I would remove the thermal compaund and apply as5. I doubt you will see much difference though if you cant be bothered.
7 Mar 2006 at 10:33 #3 ACPCUP ACPCUP Permabanned Joined 12 Sep 2005 Posts 1,149 Location Up A Tree Probably not a lot of difference in it to be honest.
7 Mar 2006 at 11:46 #4 R B Customs R B Customs Soldato Joined 22 Sep 2005 Posts 3,267 Location Manchester if you have it... use it ! going from intel heatpads to silve compound has made a mind blowing change to mine Rick
7 Mar 2006 at 12:06 #5 Squidge Squidge Associate Joined 18 Oct 2002 Posts 2,185 I agree, changing from Intel's heatpad to AS5 gave me 10c difference in load temps No idea about the stuff that comes with the Typhoon however, but if you have AS5 available, you may as well use it!
