Thermal Compound
Permabanned
30 Dec 2021
Yorkshire
What's the best stuff to put under a water block and just forget about for a long time
i have some Arctic MX-4, but for the cost of thermal paste is there is somthing more trust worth?
CPU is only a i5 13500 so not massive heat output but i don't plan on stripping the system for a long time.
unless i can find a cheap 13600/13700 before i make the change to water haha
MX-4 is fine, you'll see no real appreciable gains with more expensive paste, especially not on that CPU.
I also use MX-4 as a go to default, for sure avoid Arctic Silver 5 as it dries out over longer time, although I had slightly better performance from it (2-3C).
I usually use MX-4, but honestly, any brand will do the job.
If I've got another brand to hand I'll use it and it works just the same.
Another MX6 user here - moved from MX4 to it a few months ago. (Went from Watercooling loop to Noctua NH-D15 chromax cooler and changed paste at same time) No complaints as yet .
The correct answer is to use whatever paste you already have laying around.
No need to buy more until you run out.
This to be honest. I’ve always found very little difference between the well known brands. Usually just use MX-4 and now MX-6.
For an old system what others have suggested MX4. For a new system/daily driver Honeywell ptm 7950 thermal pads.
