So will be doing my loop tnite hopefully it goes well this time.
Two questions:
- in the instructions for the gpu block it says I can add some thermal grease to the pads that go over the vrm vram and other bits (I think, obviously I'll read that again while done it). Does this mean between the pads and the board or between the pads and the gpu block? It is optional ofcourse.
- Also thermal grease? Is that the same as the stuff you put on the gpu chip? The TIM.
Two questions:
