https://www.hwcooling.net/en/test-of-chewing-gums-3-arctic-and-thermal-grizzly-minus-pads/3/
this will give you general idea , i need some as well to replace vrm and for ram heatsinks to install accelero extreme , just not sure what thickness to go for
edit : there is diferent ones to :
Fujipoly 100*15mm 11W/m*K
Fujipoly 100*15mm 17W/m*K
Gelid Solutions gp-extreme 12 W/mK
Better than the stock pads?well these arctic pads seem to be doing ok,transferring plenty of heat to the backplate too.
As fastboy says. It's pretty critical to use the current thickness pads and be aware some cards require several thicknesses on one board. If you don't match the right thickness, some components might not be cooled or the block/backplate can be lifted away from the board.what thickness to use for vram heatsinks 1 mm or 0.5?
