Thermal Grizzly Conductonaut usage
15 Nov 2010
Hey guys,
I'm thinking about delidding my CPU and using this stuff: Thermal Grizzly Conductonaut
2 questions:
1) It says no aluminum , so the IHS is not aluminum correct?
2) On a GPU, with a stock NVIDIA blower style, Titan X, this is also not aluminum correct?
Just want to make sure I dont damage the blocks at all.
I'll also be using it with a Corsair H115i ontop of the IHS, is this OK too?
Thanks guys.
Theyre copper with nickel plating, I lap mine down to the copper anyway though as they dont seem to come very level, at least the ones ive had hadnt. I dropped my temps quite a lot after lapping it square.
