Thermal pad / tape difference
17 Feb 2006
Winchester
Either tape or pads should be fine, I wouldnt worry about using the slightly thicker stuff, 1mm aint gonna make a great deal of difference, though you may want to replace all the pads at same time if you do use a different thickness to ensure an even contact
Added pics of what I'm dealing with, if anyone care to comment. If I can't source any the same, I may well get the Akasa 0.3mm stuff and hope that fills the gaps adequately.
I was looking at this a while ago to reattach the stock cooler to my graphics card - I think the tape is too thin and would leave a gap.
You should probably check your email though. ;)
Thanks. Had a look there, but limited it to Uk search only. At least, I know they are available. That one site does have them quite expensive though. Anyway, I should find something suitable among them.
Just to conclude this thread (fingers crossed), I got some 1mm thk pads from an e-tailer after all, found last minute, although I was going to use the Ebay links Dingleberry sent me.
Did all the replacement as follows, but no noticeable difference yet - still idling at 55 under 1ghz (half load of my 2ghz core 2 duo)!. My fans were clogged with dust though. Will try gaming and see if it still hits 65.
Light blue ones are those I removed.
