My GTX 280's thermal pads are completely worn away so I'm going to replace them, however I stumbled across a post from google that stated the general consensus is that Paste is far better on GPU's (core AND memory) than pads, but paste is risky as it's capacititive (not sure what this is tbh).
Source: http://forums.guru3d.com/showthread.php?t=133823
What would you guys suggest? I'm happy to risk the paste if it's just a case of being tight on the application or is it really worth just sticking with pads?
