Is there anyway to find out what thickness of thermal pad you require for certain cards? I guess you could take off the original stuff and measure it with a vernier gauge to get the thickness.
You can buy EK pads in 0.5mm, 1mm, 1.5mm thickness and either square or thin rectangle (memory sized), they are the best imo they're the ones they use for their waterblocks.
